dovsky
Jan 1 2015, 09:53 AM
Hi I'm new to the forum. I was wondering if someone can help me. After many years of trouble-free operation, all of the sudden I'm not able to open the front hood/trunk by pulling the handle. I'm suspecting that the cable connected to the latch mechanism has either broke or come loose. But it's hard to diagnose without having the proper access to see what's going on. Has anybody experienced a similar issue? Is there a trick to open the front in case the handle cable fails? Any advice will be greatly appreciated!!! Thanks.
Happy new year to all,
Dov
Zichron Ya'akov
Israel
rnellums
Jan 1 2015, 10:01 AM
Remove the front bumper and there is an access home through which you sold be able to release the lock.
Good luck!
Jan 1 2015, 11:05 AM
Once you get your trunk open, lube the cable, lock mechanism and handle. Force from increasing friction causes the cable to pull from the latch. Lubing everything will make it work like new.
TheCabinetmaker
Jan 1 2015, 11:13 AM
If your car is 74 or prior, there are two bolts in the front of both wheel wells. 75/76 with rubber cover has 1 bolt on each side (visible from underneath) to remove cover.
TheCabinetmaker
Jan 1 2015, 11:14 AM
Btw, welcome to the world.
rgalla9146
Jan 1 2015, 11:30 AM
...... maybe you should see if it might be locked first ?
Hine62
Jan 1 2015, 11:46 AM
If you can not even move the pull lever, then it is locked. This has happened to me before. Even if you have never used the lock before, start there.
Hine62
Larmo63
Jan 1 2015, 11:58 AM
I had the same issue when I got my car. The hood wasn't locked, it hadn't been opened in years and all I had to do was pull hard on it. A locksmith could probably pick it if it is locked. I'd try the hard pull first.
barefoot
Jan 1 2015, 12:10 PM
perhaps you can get to it without removing the font bumper. right in the middle where the latch bolts on there is an access hole between the bolts for a flat blade screwdriver to be inserted, just twist once you're in there.
TheCabinetmaker
Jan 1 2015, 12:24 PM
QUOTE(barefoot @ Jan 1 2015, 01:10 PM)
No way too access that hole with the bumper on.
toolguy
Jan 1 2015, 12:29 PM
If it's not locked, then it might just be stuck/stiff from non use. . . In order to remove tension on the lock assembly, I have had success if someone 'gently' pushs down on the hood above the latch area while I pulled the release. . sometimes the front person has to jiggle the hood up and down a few times while you're pulling on the handle. .
dovsky
Thank you all for giving me great advice in such a short time. I will follow the suggested recommendations in order of difficulty. BTW, my car is a 76 with the heavy rubber bumpers, which I'm really not looking forward to remove. But I'm very glad to learn that there are ways to get around this problem.
Thanks again!!!
Dov
rhodyguy
Jan 1 2015, 12:37 PM
You may be able to get to the access hole by just removing the bumper cover. The hole will be behind the BIG impact bar. Much less involved.
dovsky
Jan 1 2015, 12:42 PM
QUOTE(rhodyguy @ Jan 1 2015, 08:37 PM)
You my be able to get to the access hole by just removing the bumper cover. The hole will be behind the BIG impact bar. Much less involved.
Great tip, thanks! It's now 8:40 PM here in Israel. So I will look at it in the daylight tomorrow morning and report back.
TheCabinetmaker
Jan 1 2015, 01:48 PM
quote name='dovsky' date='Jan 1 2015, 01:42 PM' post='2128835']
[quote name='rhodyguy' post='2128832' date='Jan 1 2015, 08:37 PM']
[/quote]
[/quote]
I think that is exactly what I said.
"75/76 with rubber cover has 1 bolt on each side (visible from underneath) to remove cover."
