PanelBilly
Jan 1 2015, 03:19 PM
Am I doing this right. I'm replacing the 14 pin connector on the body harness and I want to check that I'm using Jeff's drawing correctly.
I assume its drawn from the prospective of the connector looking from the back side with the cover off.
Click to view attachmentClick to view attachment
type47
Jan 1 2015, 04:55 PM
It's easy to verify wire to location in the plug by looking at a diagram of the relay board. The workshop manual pic of the relay board has the color coded wires of the plug coming off the board.
IronHillRestorations
Jan 2 2015, 03:09 PM
Put the big yellow wire in earlier. You might have to experiment with wire placement to get it all in the plug housing so you can get the cover to snap on without cracking it.
JeffBowlsby
Jan 2 2015, 09:54 PM
Check that connector wiring with the correct schematic/relay plate diagram for your car Billy. The 14-pin connector is not wired the same from year to year.
