I was doing some axle maintenance this weekend (replacing rear bearings, output shaft seals, etc.), and I'm at the point where I need to reinstall the driver's side half shaft. I've got the passenger one in. I removed the starter in order to get enough space to get the end out of the trailing arm -- barely! Now I can't seem to figure out how to get it back in. No matter how much I push the tranny end up over the tranny I still have 1/8 to 1/4 inch of threads on the spline end that won't get past the trailing arm opening.
Is there a secret position or contortion I need to learn? Do I need a BFH? I've got a BFH. I'll use the BFH if necessary. Just say "use the BFH" and I'll use the BFH....
