QUOTE(Spoke @ Jan 6 2015, 06:25 AM)
I believe the main switch is a FET to ground with the drain of the FET on the output. Running the unit with the output open should do no harm.
Agreed, don't use the coil as a load in testing. It's resistance is minimal and anyways the test is to see if the output is switching and the coil is not needed for that.
The issue here is that to test that the Pertronix is working you verify that the voltage across the Pertronix is ~12V when the FET is open and 0V (GND) when the FET is closed.
If you do not have a load on the high side of that FET there is nothing to "drop" the +12 V across.
So with a perfect power supply the high side of the Pertronix FET will read +12V with the FET on or off.
So you need some kind of load or the test wont work.
And with no load, I am fairly certain that it will stress the FET.
Power MOSFETs have an on resistance in the MilliOhms (5 millohms = .005)
12Volts/.005 Ohms = 2400 Amps.
Here is a simple diagram:
So if you try the test on the right, I am fairly sure you will blow up your Pertronix.
And based on the pictures above that is the configuration in the test.
Instead of a DC power supply, you could just use a DMM in resistance mode and that will not harm the FET
