QUOTE(ClayPerrine @ Jan 4 2015, 06:46 PM)
A possible alternative would be to use a wrench and unscrew the throwout arm pivot bolt from the trans case. It would have to be done through the throwout arm hole. I have never tried it with the pressure plate right up against it, so I am not sure this would work. Don't lose the spring behind the fork.
BTDT, should be BTTT as in "Been There Tried That", good luck with that.
Just keep in mind if you are forcing something or think you might break something you will.
My method took seconds (OK 5 minutes) and as soon as that nut was slacked off it let go easy-peasy.
The downside is the throwout bearing is over 400.00 these days.
What's a VGC used one worth? Pressed apart, inspected, cleaned and repacked with swepco 201.
