I'm pretty sure that a good machine shop can turn those, so long as they're within specs for another turning with what's left.
PS - IIRC it's the grooved & cross-drilled ones which are hard or impossible to turn, & then re-cutting the grooves + turning costs more than new ones! ERic Shea at PMB will know for sure, so contact him, & he sells the rotors if you need them.
You might talk to Eric Shea at PMB about Porterfield R4S street/track pads for your 914. A lot of members here use & like them.
But you'll need to do the bedding procedure at his website, in order to break them in & loose any squeal & reduce dust - as well as for best braking.
Tom
