fs096b
Jan 17 2015, 09:07 PM
how do I remove the old trailing arm bushings?
Markl
Jan 17 2015, 10:25 PM
Use a torch, heat until you get just a hint of smoke, then pry out.
I don't know what you're planning on replacing them with, but I would advise against the poly. They don't fit very well, and squeak unless they're well greased. Check with PMBPerformance and see what Eric has available.
bdstone914
Jan 17 2015, 10:36 PM
I use a gear puller and press the shaft beyond the bushing. Pry out the bushing and push the shaft back the other direction to remove the other bushing.
I don't think you are going to pry out a 2 inch bushing with the shaft in place. Other method is use a press to push the shaft.
BK911
Apr 14 2015, 10:27 AM
I used a press and pushed the shaft all the way through the trailing arm.
Easy peazy lemon squeazy.
Apr 14 2015, 11:05 AM
QUOTE(Markl @ Jan 17 2015, 09:25 PM)
Quick, easy, smelly ...
sean_v8_914
Apr 14 2015, 01:46 PM
cook that puppy out. stinky smokey
