Porsche 914-6 race car
I have decided to sell my 914-6 race car so I can move onto my next build which will be a motorcycle engined P2 sports racer. I spent 12 years building this car and raced it for about 5 years. It is a very fun car to drive with good manners on track. If you are looking for a car that is very unique I offer this car for $30,000. You can email me at neil.cawley@comcast.net.
Engine
• 2.3 liter six, 66mm stroke x 86mm bore ; Zero hrs on the engine
• 10:1 compression, JE pistons with biral cylinders
• Dougherty Racing Cams DC60
• Zenith 40 TIN carbs with 40mm chokes
• Twin plug heads fired by two distributors
• Two MSD ignition boxes and coils
• 3 gallon oil tank for the dry sump system
• 4 rib oil pump
• Stock 2.0 liter rods with ARP bolts
Transmission
• 901 Porsche gearbox
• Open differential
• Gear ratios A, I, N, S, X
o These gears are good for Road Atlanta and Roebling Road
• Stainless flywheel with twin disc Tilton 7.25” clutch
Chassis
• Right hand drive
• Open cockpit
• Kirkey racing seat
• 1 ¾ , 0.095” thick main roll hoops
• Front suspension modified to lower and provide 1 degree negative chamber per one inch of compression
• Front shocks are Bilstein Scirocco ; 23mm front torsion bars
• Rear shocks Proshock
• Front sway bar
• 911 A type calipers on the front and 911 M type calipers in the rear
• Vented rotors
• Carbon fiber/ honeycomb doors, deck lids, and dash
• 15 gallon ATL fuel cell
• Car weighs with fluids 1700 lbs
• Car has a SCCA log book
Wheels and tires
• 2 BBS 7 x 15 currently on the front of the car
• 2 BBS 8 x 15, not used
• 2 Enkei 7 x 15 currently on the rear of the car
• 4 Compomotive three piece wheels with centers like the BBS’s
• Goodyear racing slicks, 23.5 x 9.5 x 15
Spares
• Assorted transmission parts
• Parts for a magnesium cased 2.0 liter
• Front control arm
• Rear control arm
• Assorted fiberglass fenders and other body parts
• Spare brake pads Hawk blues
• Gaskets
