Full Version: What I did today
jwalters
smilie_pokal.gif UPDATED AS OF FEB 07 @ 1837!!![/B]
[B]On page 2
biggrin.gif First off I want to give a icon_bump.gif To redshift----thanks man--
Well, the weather was good to me--and I got some stuff done.
This is now my STAGE II : The Tub
Threw my mojo down---and I believ I am on the path to salvation!!!! biggrin.gif
jwalters
jwalters
jwalters
jwalters
biggrin.gif Here I got my new battery tray on and got both of my trunk pivot frames located and welded....
jwalters
biggrin.gif Here I got my firewall clutch tube repaired and reinforced....
jwalters
biggrin.gif Roughing in the flares---
jwalters
biggrin.gif Almost done with this one--
jwalters
biggrin.gif And lastly--a great big shout out to Engman--got my new rear sway brackets welded and also got my new aluminum foot board--first rate there buddy--you helped me in this--thanks!!
jwalters
biggrin.gif Oh yea, and one more--I got my factory front sway mount locations drilled---I am pulling the fac. sway off of the donor car you saw in the other pics---
Allan
jwalters
biggrin.gif Here is a pic of before----This was taken on Dec. 20th 2004
rick 918-S
monkeydance.gif keep posting pics. That will help you stay focused! aktion035.gif
URY914
Paul
machina
the flares look awesome. Can't wait to see the result.
What wheels are you going to run?
jwalters
biggrin.gif Thanks guys! I am running 7 inch cookie cutters with a polished outer rim and metallic blue inset..
Cannot wait--I took two weeks of leave which is coming up in a few days--it is going to be a ball buster marathon!!! beerchug.gif
machina
QUOTE (jwalters @ Feb 6 2005, 09:42 AM)
Make sure you got all the little parts you need. Waiting on parts is a bitch when your pressed for time.
jwalters
biggrin.gif I have EVERYTHING!!! I have boxes of stuff--new and old all over the place----yes- sir---out with the old and in with the new....
Now, if you pardon me--there is a coors light with my name on it and some glazing compound that is ready for finish---one flare almost down!!! beerchug.gif
jwalters
smilie_pokal.gif Right front flare---completed!!!!
Yippie!!!
jwalters
TC/914
Looks great! Could you go into a little bit of detail on how you installed the fiberglass flares? Did you use an adhesive between the flares and the body metal? Why are there two rows of holes, one with rivets, and one without. Did you leave the rivets beneath the fiberglass/tiger hair "mud" coat? What kind of rivets, steel or aluminum? Etc., etc.
I ask, because I'm almost ready to install my own set of FG flares and I'm not sure of the best/longest lasting method which will both keep the flares affixed and rigid, yet not cause the fiberglass or "mud" to crack later on due to cold/ flexing /etc.
Any help would be a REAL HELP right now!
Thanks,
TC
jwalters
biggrin.gif Thanks man--those extra holes was a mistake on my part--but they also turned into a blessing in disguise!
I realized after I had mounted them the first time that I had room to move the screws back and grind down the edges flush with the metal. This enabled me to use much less filler--I am using bondoglass--it has proven itself to me.
I did not bond the flares to the metal--I instead used aviation grade screws with washers and nylock nuts on the backside-I used a countersink to sink the heads below the top layer of glass-this proved to me to be immensley strong--also, I live in a region of the country where the drivers are not good--the chances of me having to remove these to do repair is too great. This has enabled me to do just that with negligible breakage of removing the flares which will expidite repair.
So with this in mind those holes actually helped me when applying the glass. So in effect they are somewhat bonded--but only for cosmetic concerns.
Make sure you mark out your outline of the flares to the fender. Then mark another line 1&1/2 inches inside this line and cut--this will give you a lip to work with. No matter how you decide to attach yours--use screws!! This will hold it in place and pull the metal out to the contour of the flare. Keep your screws as far to the inside as possible so you can grind down the edges as flush as possible--then a good couple of coats of filler and voila--
TC/914
Screws and nuts . . . NOT rivets! Of course, what a great idea!!
TC
jwalters
QUOTE (TC/914 @ Feb 6 2005, 02:10 PM)
TC
biggrin.gif Thanks--I would never use rivets for this--those flares are not in shear--they are in tension--not that a properly driven rivet would not hold it--but I put 200+ miles a day on my car and need something heavy for the wear--keep up with me--coming soon I am going to be making massive updates on an almost daily basis--got some time off coming and it is going to be a marathon!!!! beerchug.gif
Lou W
Aaron Cox
sweet!
so miles showed and helped you out?
jwalters
QUOTE (Aaron Cox @ Feb 6 2005, 02:26 PM)
sweet!
huh.gif No he did not----does he live close to me????
I am in Davie Fl....Thanks for the kudos!!!
Aaron Cox
QUOTE (jwalters @ Feb 6 2005, 12:38 PM)
sweet!
First off I want to give a  To redshift----thanks man--
thats why i asked
jd74914
front flare looks good; i would have never thought of using screws smilie_pokal.gif
jwalters
QUOTE (jd74914 @ Feb 6 2005, 04:19 PM)
biggrin.gif Thanks--they are a really good fastening system---I have no worries about de-bonding at all--and unlike the sheetmetal screws with the coarse thread--no worries about the metal fatiguing and the threads losing grip--with the nylock nuts--I set the tension and it will stay there--always.. beer.gif
jwalters
FEB 07 UPDATE!!!
smilie_pokal.gif cool_shades.gif NEW TOYS!!
THANKS MORPHNSPECTRA!!!
This is my back pad replacement carpet--doing away with the pad--I can tell you from looking at this that there is so pretty good sound proofing built in!!! beer.gif
jwalters
jwalters
jwalters
jwalters
jwalters
smilie_pokal.gif And another shout out to.......
jwalters
idea.gif Now I just gotta figure out where all those carpet pieces go...... blink.gif
rocking nana.gif drunk.gif party.gif birthday.gif girlboing.gif monkeydance.gif rock_band.gif drooley.gif
