I was going to install the crank into the case today (2.0 GC).
I tried to mate the crank thrust bearing to mark it before sliding it onto the crank, unfortunately bearing would not fit into the case, the distance between the thrust surfaces was too narrow.
the old bearing and it had a gap between the thrust surfaces of 22mm the new one is 21mm
Anyone got any info/advice on this problem?
