Sea Dragon 914
Jan 26 2015, 10:52 AM
How do you install the droplink bushing into the droplink? I tried using a vice to press it in after greasing the bushing and link and all that happenned is the bushing compressed. I was going to try to put the bushing on the ball link then use a large pair of pliers to squeeze the droplink onto the bushing.
I recall getting the droplink on the trailiing arm was a bear and having to use a long prybar to force it on.
Thanks,
SD
Larmo63
Jan 26 2015, 10:59 AM
I did it on my bench with a vice and some patience. I didn't heat the plastic up, but you kind of get one side going in and start to clamp the other side. Once the plastic is in the round ring, I used a hard rubber mallet to finish them in. They look a bit grotesque going in but they reshape themselves once seated. I did all four in about twenty minutes.
They WILL go in. (it seems as if they won't, or don't want to at first)
toolguy
Jan 26 2015, 11:20 AM
Big C clamp
JawjaPorsche
Jan 26 2015, 11:25 AM
Grease helps too!
Sea Dragon 914
Jan 26 2015, 01:25 PM
QUOTE(JawjaPorsche @ Jan 26 2015, 09:25 AM)
Grease helps too!
Thanks everyeone! I'll give it a try this weekend.
Mark Henry
Jan 26 2015, 01:33 PM
Put the bushing in boiling water.
