Full Version: upgrading frt sway from 15-19mm
d914
Ok I got the 19 mm sway and new bushings. What else to I need and any gotcha's do I need to know about or is a straight forward bolt out bolt in???
xsboost90
and if one is to run 160lb springs in the rear w/ no rear bar, what size is recommended for the front? 22MM?19MM?
sorry to pirate your thread.
d914
my guess, 50/50 shot, more spring more bar, go 22mm. I've got 130's going on the back.
Aaron Cox
ive got 140 lb springs with a 23mm bar up front w00t.gif works good....
puttin on a rear bar too.... lots of front bar to compensate for it biggrin.gif
J P Stein
There is a 914 "sweet spot" set-up for a mild AXer.
140-160 lb springs...no rear bar.
19 mm front bar set full soft & stock T-bars.
This set-up gives mild oversteer.....to lessen (if that's what you want for track, for instance) stiffen the AR bar.
d914
xsboost90
i can deal with that!
d914
airsix
I've got 21mm front torsion bars, 19mm front swaybar, and 180# rears. I very quickly ran out of front bar. sad.gif Next up will be a new Tarret bar.
-Ben M. (severe oversteer)
seanery
Greg,
I haven't done the upgrade, but I've installed a 15mm into a car that didn't have one.
Do the droplinks fit on the new bar?
Do you have all the bushings for the new bar?
If so, it should be pretty easy. Remember one side gets the bushings put on before it goes in the car, the other has to wait till the bar is in place.
d914
thanks got it . I was more worried about fitting through the triangles but no prob...
Now rehabing all the little pieces and standardizing hardware..A little paint and a little cleaning and having fun.
New ignition wires, cleaned up some miscellaneous wires, laid out most of the new fuel system and got the new sway in.......good weekend....
