It's been about 10 months since I updated this thread. Have gotten much done, especially in the past few months.
This car is a solid driver and is definitely a keeper. Now I'm looking for an '84-'89 Carrera to tinker with but man are they expensive.
Anyway, here's the list of what me, my buddy or a shop (tires and alignment) have done since I bought the car last January. Oil and filter changes are not shown (three oil and filter changes last year).
*Front wheel bearings
*Bleeder valves and rubber caps, front and rear
*Front and rear rotors
*Brake pads, clips and inner adjustment covers, brake hoses
*Bronze pedal bushings; cleaned and treated area underneath cluster and repainted the cluster
*Turbo tie rod kit and alignment
*Ball joints, pins/bolt, nut, washer
*Clutch tube
*Trigger points
*Speedometer cable
*Seat belt decals
*914rubber: targa holders, screw caps (need to be installed)
*Engine lid rubber
*tranny seals, speedo drive o-ring and shaft seal, cv joint bolts
*Radio
*Fuel pump - aftermarket Bosch 69133 and new fuel filter
*H6024 - headlights
*Fixed fresh air and heater blowers
*Set of 5 Fuchs alloys, caps and lug bolts
*Shift knob group buy (not installed; kept original)
*Headlight arm with clips (not installed)
*Heater lever knob
*Seat adjuster handle driver's side
*2.0 TPS board
*2.0 throttle body gasket
*Transmission tail cone gasket
*Front trunk drain tube
*Sunvisors
*Seat belt interlock relay - bypassed starter wires and removed relay
*Fuel injectors
*Clean AAV
*Windshield wiper blades
*Seat belts
*Relay board
*Ignition switch
*Pedal board hardware
*Door light switch rubber surround
*Drivers side deflector/cooling flap
*Flexible hose pcg261235a
*Accelerator cable
*Passenger fog light grill
*Passenger turn signal lens
*Rear glass - Napa 4196 Martin Senour butyl tape
*Refinish flywheel
*Flywheel seal, pilot bearing, felt washer, clutch fork pivot bearing, bolts and locking plate
*Sachs clutch kit
*Used outer rocker covers
*Rocker panel rivets - didn't use
*Fuel injection boots
*Weatherstripping for engine bay
*Spark plugs - NGK 7432 B6ES
*Engine front and rear seals, gaskets
*Injector seals and intake gaskets (manifold and plenum)
*Dist cap, rotor, points, condenser, plug wires, dist seal, oil tower gasket
*Breather and vacuum lines
*Shift bushings
*Used transaxle (original wouldn't shift into 4th or 5th)
*Inspection plug cover
*Fuel lines and hoses - Tangerine Racing
*Expansion tank hose 3 mm
*Expansion tank and sender gaskets
*Gas cap gasket installed
*Gas tank - acid etched and cleaned
*Dash top - 914rubber group buy
*Rear springs 100lb
*Front strut inserts (Sachs)
*Rear shocks (Sachs)
*Targa top handle - front driver's side (used)
*Drivers side door brake
*Clutch and brake pedal pads
*Heater hoses
*Vinyl kit for floor
*Sheetmetal from restoration design
*More sheetmetal
*Muffler
*Reverse light switch and plunger
*Pass side taillight lens
*LEDs for parking lights and rear lights (front set ordered last week)
*Side markers - used assemblies and new gaskets and clips
*Trunk rollers
*Shift knob crush sleeve
*Fender to cowl seals
*Door actuator cams
*Fatmat
*Tires
*Seal along bottom edge of rear window and engine lid
*Steering wheel - refinished at Custom Craft
*Horn - 90134782301 spring return and 91161510901 relay; aftermarket horns
*Horn spring plate, new contact ring and base plate
*Battery mat
Still to do:
**Fuse box cover
**Top seals, door seals, trunk seals
**Jack tube covers
**Odometer gear
**Fix clock
**Rear trunk lid :/ find good used or repair??
**Sail panel vinyl kit
**Recover seats, center console and door panels; might as well do carpet too
Eventually the car will be stripped and repainted but maybe next year.
Here's how she sits now:
Click to view attachmentClick to view attachment
