Got to the shop an hour earlier than Mike's planned arrival time so I went to work on the left qtr. to taillight panel corner weld in.
Not quite all finished and tidied up, but back together.
Only shot I took.
Click to view attachmentAfter welding I checked the taillight alignment again ................. don't want any future surprises.
Then I spent a couple hours with Mike (Warpig) sorting thru his engine cleanup pile. After that we headed to lunch. After returning from lunch I began to work on fitting the trunk panel. I start tweaking the rear flange to get the fit I want for a great weld in.
Click to view attachmentClick to view attachmentAfter I feel that I have the trunk pan in the correct place I begin the work of creating the removal exhaust shield. Panel just fitted, not welded. This time I'll do the work with the trunk pan on the work bench. Which is much easier to work with. But nothing to measure too. Which creates its own issues.
Click to view attachmentClick to view attachmentI should have crawled under Mark's car in the other room for measurements.
My first swing at it it was too close to the tranny mounts. Its going to be moved a 1/2 closer to the taillight panel. This afternoon we're going run out for a couple more hours of work and I'll go under the other car to compare notes.
While I'm working on the trunk Super In Law has been creating the two new inside trunk/fender corners. Lots of trial and error. One would think I could have got them from the donor part. But the spot weld cutting and delayering didn't leave too much.
And we're fitting it to the work we did prior to deciding to replace the sheet metal.
So time for some welding ...............
Click to view attachmentClick to view attachmentWelding was a little bumpy with all the left over factory brazing to work around.
Prior to the inside corner weld in I did get the bottom portion of the taillight panel and qtr. panel welded together and tidied up. But I forgot to shoot a couple pictures.
