One of the fun parts about doing a 914-6 conversion is coming up with a game plan for the wiring harness action in the engine bay.
Going from a 914-4 wiring harness through a 914-6 engine relay board and interfacing it all with an MFI engine does have it's challenges.
I wanted to make use of as much of the existing wiring in the 914-4 wiring harness as possible.
Also needed to use the 914-6 relay as there is something called an RPM transducer (or speed switch) that is nice to have with an MFI system to eliminate backfiring on deaccerlation.
Plus I'm going "old school" and using the on board voltage regulator vs. a built-in regulator in the alternator (newer ones are this way).
Click to view attachmentSo here's me with wiring diagrams for a 1971 914-4, 914-6, and 1973 911 E,S,RS trying to figure out what goes where.
This was made all the more challenging by the fact that my wife and I just had twins.
Talk about reinventing the wheel a couple of times.
I'd get so far with my plan of action then it was time for the twins.
Then where was I? How far did I get?
Maddening really, but eventually I got there.
Had to learn how the std Porsche round relays worked, how the cold start relay and accompanying thermo-time switch works, and how the RPM transducer and fuel shutoff solenoid on the MFI pump worked.
After that....simple as connecting the dots.
I'll have to add a couple of additional wires down the tunnel for the different 911 gauges I'll be using....oil pressure/oil temp.
But everything else can be dovetailed into the existing wiring.
Even on the 914-6 engine relay board, I'm repurposing the rear window heater relay as the fuel pump relay.
Eventually, I put together my own 914-6 relay panel current flow/wiring diagram.
