2.7 MFI engine all mounted up on Rothsport's engine dyno....ready to go.
Click to view attachment Better view of the amber fan shroud and the milled-down turbo valve covers.
911 headers were used instead of Ben's 1-5/8" SS 914-6 heat exchangers as they fit on the dyno better.
Same diameter and approx length, so power outputs should be similar with Ben's HE's.
On the car, obviously Ben's HE's will be installed.
Using a Dansk single outlet sport exhaust.
Will try to compare power output with a Leistritz single outlet factory supplied muffler as well....later.
Click to view attachmentSpecs on the engine.
Factory 2.7 MFI identical.
Mahle 2.7 8.5:1 pistons/cylinders, Webcam reground the cams to S/RS specs, T heads opened up to S/RS spec with
S sized intake/exhaust valves, Pertronix ignition, Clewett spark plug wires, Series 900 amber fan shroud,
Mark Motshagen refinished fan/fan housing, 4 rib oil pump, distributor recurved to RS spec, throttle bodies
rebuilt by Burnham Performance to S/RS spec, plastic intakes bored out to S/RS spec, Carrera pressure fed tensioners,
MFI pump rebuilt and modified to RS spec by MFIWerks, all engine plating done by Tru-6, new Stoddard's 914-6 high
efficiency oil cooler, PartsKlassic high output coil with matching solid state CDI box, etc. HA
