She's home finally.
Had a false start last week.
Half way home, the engine started to cut out and wouldn't run at any kind of throttle.
Trailered back to Rothsport, and they tracked it down to a fault in the fuel shutoff solenoid for the MFI system.
Beautiful day in Portland, so I went back out and fetched the car.
Click to view attachmentClick to view attachmentClick to view attachmentSafe at home in the garage.
Click to view attachmentSharing space with its stablemate.
Click to view attachmentLots of little projects to take care of besides driving it as much as possible in the next week or two while the weather is nice.
Typical Portland winter monsoon season is coming soon.
Need to lower the mirror on the windshield so I can behind me better.
Lubricate both the steering wheel and gear shift....squeak, squeak.
Purchase and install a small steering wheel. The current 380mm factory wheel is just too big for my long legs. Looking at a 350mm aftermarket of some type.
Need to purchase a new micro switch for the MFI fuel cutoff circuit. Mine is obviously dodgy. The one that is failing was new when I purchased it. Bad QC I think.
Repair and repaint right corner of the front valence. Tow company jacked that up with their tow straps getting me to the shop initially.
Nice set of Coco floor mats to match what I have in the trunk.
Copy of the prop rod that some of the 914-6 GT's used. Kelly Moss will make me one this winter. Then I can ditch the long fiberglass rod.
Purchase the heater box barrel nuts so I can finish the heat/defrost install in front of the engine.
My parking brake light just stays on, so I think the little switch down by the parking brake handle is no good. Again some bad QC on some of these parts.
Long term projects for next year include:
-possibly softening up the suspension by going with 19mm T-bars (current 21mm) and 125# rear springs (current 150#). Just drive and we'll see for now.
-gearing is very short. Great for auto-x, rallying, etc. Long drives on the highway, maybe not so much. Again it's not an immediate issue. But might look at changing out 5th and possibly 4th gears.
-refinish and repaint the roof. Looks fine, but if you're a perfectionist, it might need some attention. Ha
That's all for now.
I'll get some more close up pics of various parts of the car up here in the coming weeks just for fun.
Car is running cool so far. Just 90C after everything is all warmed up. We'll take a wait and see approach to adding the aux oil cooler. Likely need an auto-x on a very warm day or a track event to get the temps up there. Or some 105F weather as we sometimes get here in the summer.
Green car's nickname is Kermie.
914 will be Snoopy....black & white with an attitude.
