QUOTE(Mikey914 @ Feb 11 2015, 08:20 PM)
I can make adapter plates for these, but it would be nice to know what the deal is? I never dreamt they wouldn't like up as both parts were OEM. It wasn't until I test fitted these that I discovered the issue. I did have one customer recently ask, but didn't see the issue until I did a check fit.
I'm assuming that you're talking about the holes in your bumper top being wider spaced in this pic Mark?
I don't have easy access to my NOS rear top pad & the F+R set of yours to cross check them (& yours were in the early pre-reinforced run of +/- 2009-10), but I do know that everything lined up correctly when I disassembled my rear bumper, top pad, license lights, etc.
So AFAIK the light was the same 70-74 - & so was the top pad & it's mounting points - & they have fit properly on my & all other friends' steel bumpered 914s from that period.
If this screw-hole misalignment is the problem, is there any chance that there was some stretch induced when you molded the top pads?
Or maybe the one you used as a master had the holes mis-placed??
... or maybe re-drilled wider to use a different replacement light base??
Also, the light in you pic is very close to the ones used on my `88 Westy & maybe it's not the same size, but someone tried to use another VW license light on the rear top pad you used for the mold master, & drilled it to fit a different light.
I'd suggest that you try this license light on an actual OEM rear top pad & see if you still have a problem, & the light vs. a known OEM one on an OEM bumper top pad. Someone up in your area must have an all original 914 set-up so you can cross check it.
Good Luck!
Tom
