rosenfe
Feb 12 2015, 09:09 AM
Pelican tech article mentions 34-35 btc as a good setting.any opinions?
Steve Snyder
Feb 12 2015, 05:33 PM
Seems high to me. I'm at 27.
Dave_Darling
Feb 12 2015, 06:36 PM
Which distributor? What cam? Which carbs? Engine configuration? Exhaust?
All of those have at least some influence on what timing is needed. The best way to set it is probably to use a dyno with a good set of gauges, including cylinder head temps for all four cylinders.
--DD
Steve Snyder
Feb 12 2015, 07:47 PM
Well, in that case you would also need the exhaust gas temps for all four cylinders.
...and 35 will still be high.
somd914
Feb 12 2015, 08:23 PM
I'm running a 2056, Webcam 86 cam, Weber 40 IDFs, Pertronix SVDA distributor.
I've found 27-29 works well for my config. But I don't have a CHT gauge.
rosenfe
Feb 12 2015, 09:09 PM
weber 34 ,stock cam,distributor.ill just stay with 27.wondering why pelican article indicated 35 btdc?
