I'd like to change the oil and filter and check/adjust the valves and give it a good general once over.
So... I have the oil (brad penn 20-50) but need to order the filter and...
what else?
I am thinking probably at least the oil plug/strainer crush washer and gasket set.
Should I go ahead and get the whole maintenance kit from pelican?
kit includes:
oil air & water filters, valve cover gaskets, oil drain plug gasket, spark plugs and distributor cap rotor & points (& condenser- where applicable ) I figure if I don't need some of this stuff now I may in the future.
I'd rather do it myself but am an amateur wrench at best and never worked on any Porsche, any mid-engine anything or any A/C engine or adjusted the valves on anything. talk about tabula rasa! (I have read many threads and manuals -Haynes and others, it all seems pretty straight forward but still nervous to tackle this stuff alone)
Any recommendations for a good shop in the Fort Worth area?
Or anybody Fort Worth local wanna help walk me through some of this? I'd be willing to pay for somebody's time & I can come to you or I have ample space here and of course I'd provide the beverages and barbeque. Like I said I'm a blank slate here, anybody wanna take this opportunity to
Thanks in advance. chime in here or PM me -any advice or suggestion is welcome!
Chris
