A am a newbie and need some help
I want to install electronic points is this possible on a distributor with vacuum advance and retard? If its possible please give some recommendations
The PO has plugged the advance line any ideas why he did this?
The car is a 2.0 1976 GC smog motor with smog removed, there is no tap off on the throttle body for the advance so I guess the retard is only used when decelerating, is this correct?
Distributor type: 039905205A
