I need the fitting that connects the tunnel shift rod to the base of the shifter on a side shift assembly. It is the fitting that claps on the then splined end of the shift rod in the tunnel and is #19 in the photo at this link:
http://www.pelicanparts.com/914/Parts/Peda...ge_side_big.htm
There are two #19's the shift linkage and the fitting itself. I just need the fitting.
Thanks, Bill
