a9146luvr
Feb 7 2005, 08:28 PM
When does it become unrealistic (not just cost effective) to save a 914? I have one that has rust thru in both outer clamshells at the bottom of the doorjambs (jack posts are bad, inner clamshells seem ok). The engine shelf (batt side) is gone as is the area under the battery, to where the fuel lines perforate the tin, and under the battery tray is flakeing real bad although suspension appears not to be drooping, yet! I'm looking at $1200 in repair panels alone, right? Then gotta add fitting, welding, finishing, eng/tranny rebuild etc! HELP. Thanx guys.
vortrex
Feb 7 2005, 08:34 PM
sounds way too unrealistic (not just cost effective). why would you be interested in this car when in TX there must be a multitude of good 914's?
a9146luvr
Feb 7 2005, 08:50 PM
If there are alot of 914's in central texas, i have not seen them, and my wife says 914's are like boobs i can see 'em (over) a mile away, bouncing or not!
vortrex
Feb 7 2005, 09:04 PM
I am of the belief that if need be it is worth traveling for the right car or shipping one in. all depends what you want to do though. if you want to play with your welder try and patch together a ruster. if you want to drive one start with something that's not a total mess. there will be plenty of other things besides rust repair to keep you busy.
balthazar
Feb 7 2005, 09:12 PM
There is a good roller here in the local area for $250
I also know of another car in the area for $1000 that runs and drives
They both need lots of work, but my point is both of those cars are less than the $1200 for rust repair panels you quoted. And they are relatively rust free...They are out there, jus gotta look harder!
riverman
Feb 7 2005, 09:39 PM
It's not the car, it's you. How much do you want to do? How much do you want to learn? I'm of the opinion that every 914 is worth saving.
dakotaewing
Feb 7 2005, 11:10 PM
As others have said it is up to you, how much time and money do you want to spend... If the car is not an original six, or a rare 4, I would seriously consider getting another roller-
But, that is just my opinion...
Thom
SpecialK
Feb 8 2005, 01:08 AM
QUOTE (riverman @ Feb 7 2005, 07:39 PM) |
It's not the car, it's you. How much do you want to do? How much do you want to learn? I'm of the opinion that every 914 is worth saving. |
riverman's got a point.......how much work are you willing to put into it, and what skills and tools do you already possess?
Project cars can be fun [not].
But if you'd rather be driving...look into a good roller.
Brent
Feb 8 2005, 02:53 AM
I second that opinion. Thats what sets the 914 apart.
