I bought these tie downs:
But the stock bolts seem to be a little short to stick the tie down between the shock & trailing arm while retaining the thick washer under the stock bolt head.
The stock bolt is 18mm X 1.5 X 130mm.
The tie down is 5mm.
Bolts that large typically come in 10mm increments, so I would need 18mm X 1.5 X 140mm.
I have found them but for $25 ea plus shipping.
Anyone have a source for the bolts cheaper or a trick to installing these with the stock bolts?
Are the bolts that have the attachment points for the rear swaybars just a tiny bit longer?
