rick 918-S
Feb 28 2015, 09:53 PM
Are these shear bolts holding the switch to the dash?
Cairo94507
Feb 28 2015, 10:08 PM
I am pretty sure they are.
Socalandy
Feb 28 2015, 10:15 PM
YEP
altitude411
Feb 28 2015, 10:41 PM
Did you buy Andy's camera?
rick 918-S
Feb 28 2015, 11:07 PM
QUOTE(altitude411 @ Feb 28 2015, 10:41 PM)
cell phone
r_towle
Feb 28 2015, 11:09 PM
Yes
type47fan
Mar 1 2015, 12:55 AM
Hey Rick,
Here's a picture of the ignition switch I have. Notice the small hole in the bolt. It was drilled and used to back out the screw when the switch was removed from the dash.
rgalla9146
Mar 1 2015, 09:14 AM
They are easily removed with a sharp chisel dug into the edge to rotate it counterclockwise.
They are still available..... or can be re-used by cutting a slot across the head with a hacksaw and tightening with a screwdriver.
Larry.Hubby
Mar 1 2015, 07:32 PM
They also have a slot machined into the end of the screw so you can come in from the back with a small screwdriver and back the screw out.
rick 918-S
Mar 1 2015, 07:42 PM
I was asked to make the piece that holds the switch to the dash. I pulled my face plate to take a look at the switch and noticed the shear bolts. Here's the plate I made.
type47fan
Mar 2 2015, 04:35 PM
P/N 911.347.613.00
Thanks Rick!
QUOTE(rick 918-S @ Mar 1 2015, 05:42 PM)
