QUOTE(screenguy914 @ Mar 1 2015, 08:19 PM)
Sounds like there's too much vertical play in the distributor shaft. Remove the distributor and inspect. If the cam lobe is okay, add'l thrust washers can be installed to decrease the slop. Otherwise, shop for a replacement in good condition. They should be plentiful, yes?
Sherwood
Shim.Check for worn bushings,replace or re-bush with oil-lite bronze to minimum clearance and install a pointless cd ignition for a fatter spark.
A Vertex magneto is optional too,tho pricey.
From the Samba
(earthquake)
OK guys
just don't do what a friend of mine did, He won a magneto at a sand drag giveaway. On the way home driving he reached in the back seat and grabbed the mag and was looking at it, he was holding it between his legs when he gave the gear a turn. He said he pulled over to the side of the road and just sat there for about 15 minuets untill he could feel his balls again, said it was the worst thing he ever did and he got his cought in a radial arm saw once.
