O.k. so this crazy car would not start tonight. It cranks, but won't fire. Fuel pressure is good, gas is flowing but no spark. This has happened before but not for several months. Could these 2 things be related?
What would cause the right side signal to come on at all if the ignition is off position? Left one does nothing. With ignition in 1st on position both work and flash.
- car not running starting is a phenomenon that last happened about 2 month ago. Weather changed drastically last few days with high humidity. Had been cold and dry and it had been running perfect. Ran last week .
it hast to be some kind of electrical Short that is intermittant. Where to look first!
Btw the fuse and relay board under dash is a new one put in last year. Egman variety I believe.
could it be the ignition switch?
