Had small leaks on my tractor quick connect hydraulic fittings.
Several years ago I bought one of those Universal Oring replacement kits.
Probably has 100 Orings in it.
So removed the old hard Orings and installed same size from the kit after
checking required size off manufacturer website.
With newly installed Orings the leaks continued
After some research I thought the problem might have been wear on the
quick connect couplers. So replaced those.
The leaks continued.
Next time I was walking around HDepot I grabbed same size Orings out of the
plumbing repair section. When I got home researched the Oring manufacturer
website to make sure they were suitable for pressure and hydraulic fluid- they
are. So installed them in the quick connect couplers.
The leaks stopped immediately!
Lesson learned- Orings sitting around for more than 2 years should probably be
thrown in the trash. Even tho I stored them in a dark cool place and they felt and appeared in good shape they had apparently shrunk or deformed or whatever.
