Randal
Feb 11 2005, 03:43 PM
Anyone have one lying around?
If you do have to ask I'm going to blame Andy.
ClayPerrine
Feb 11 2005, 03:46 PM
"intermediate shift rod"?
What part do you mean? Internal to the transmission, or one of the external ones?
Randal
Feb 11 2005, 03:48 PM
The rod that runs from the engine compartment up to the shifter. The shifter has a cast piece and bolt that ties to it...
Feb 11 2005, 03:49 PM
QUOTE (Randal @ Feb 11 2005, 01:43 PM) |
If you do have to ask I'm going to blame Andy. |
i had fun with the , that's all i have to say about it ...
Andy
eeyore
Feb 11 2005, 04:41 PM
I probably has one... lemme check tonight. All or part? I suspect the "...cast piece and bolt that ties to it..." only
Feb 11 2005, 04:52 PM
QUOTE (Cloudbuster @ Feb 11 2005, 02:41 PM) |
I probably has one... lemme check tonight. All or part? I suspect the "...cast piece and bolt that ties to it..." only |
nope. he needs the *rod*, not the shifter part ...
i had to saw off the rod at the rear coupler because the setscrew was stripped and didn't come out.
and we didn't have much time, so out came the hacksaw.
all he needs is the rod that goes between the shifter and the "behind the firewall" coupler.
btw. we're talking sideshifter here ...
Andy
eeyore
Feb 11 2005, 05:21 PM
OK.
Randal
Feb 13 2005, 06:31 PM
Here is a picture for the side shifter rod. The dimensions are:
Overall the shaft is approx. 31" long.
The tube diameter is approx. 3/4".
The shaft on the shift assembly side is 16 5/8". This 1/2" shaft is welded to the larger 3/4" tube.
The final 2" on the shaft has splines cut into it.
scotty b
Feb 13 2005, 06:34 PM
Mueller
Feb 13 2005, 06:44 PM
if you need the part that attaches to the shifter and sit's inside the middle tunnel, I have one....
Feb 13 2005, 07:46 PM
QUOTE (Mueller @ Feb 13 2005, 04:44 PM) |
if you need the part that attaches to the shifter and sit's inside the middle tunnel, I have one.... |
yes, that's the rod in his picture ...
inside the tunnel, from shifter to coupler right behind the firewall ..
Andy
Mueller
Feb 13 2005, 07:52 PM
$10 work for you??
Feb 13 2005, 07:59 PM
QUOTE (Mueller @ Feb 13 2005, 05:52 PM) |
$10 work for you?? |
don't ask me, as randal!
i was just the one who cut it ...
Andy
Randal
Feb 14 2005, 08:28 AM
Yes!. I'll PM you for directions.
Thanks Mike.
Mueller
Feb 14 2005, 12:39 PM
good news/bad news
good= I've got the correct part for you....
bad= the hole for the "cone" set screw is tweaked,
last time I had to repair one of these, I filled the hole with JB Weld, and inserted the correct set screw covered with a plastic sheet to form the correct female pattern.
if you want to try this, you can just have the shift rod for free.....
Feb 14 2005, 03:31 PM
QUOTE (Mueller @ Feb 14 2005, 10:39 AM) |
last time I had to repair one of these |
just weld it up ...
Andy
Trekkor
Feb 14 2005, 08:00 PM
Randal I will have one for you on Sunday.
Feed me and I will deliver it
KT
Mueller
Feb 14 2005, 08:06 PM
Randal is going to need it Trekkor...he's decided to pass on mine due to the damage....being a dedicated track/auto-x car, it is wiser to have a known good part than a part that has already been comprimised.
Trekkor
Feb 14 2005, 08:20 PM
Remember the free 914 last year I gave away?
It's coming back home...
KT
Mueller
Feb 14 2005, 08:28 PM
is that a white interior??? look nice, but I could never have a car with such a light colored interior.....
Randal
Feb 14 2005, 08:36 PM
QUOTE |
Feed me and I will deliver it |
Now that is a done deal; your choice of restaurants we have here. Have you ever eaten at Original Joe's in San Jose?
Or I have to be in Napa next week anyway; maybe we can hit that great place at the end of Cutting Wharf Road?
Trekkor
Feb 14 2005, 08:44 PM
You come here...
That way I can get home early.
I'll even pop it out and clean it up for you.
Moore's Landing on Cutting's Wharf.
KT
Feb 14 2005, 09:17 PM
QUOTE (Mueller @ Feb 14 2005, 06:28 PM) |
is that a white interior??? look nice, but I could never have a car with such a light colored interior..... |
you HAVE TO save that interior. do you have any idea how rare the original white interior is ????
EASY had a car with white interior not too long ago. it was in perfect condition too ...
Andy
