Guys
I'm having a continuing and frustrating problem with my 914 rally car which is presently preventing me from entering any events.
The problem is this: when up shifting or down shifting to 4th, sometimes it goes into 4th so that when I drop the clutch it's in 4th gear. While other times, I drop the clutch and it's as if it's in neutral. There's seemingly no noticeable difference from the gear stick whether it's in gear or not. It's a complete unknown as to whether or not it's in ot not. The only way I know is when I drop the clutch and give it some loud pedal, sometimes it's in 4th gear and we're continuing with our forward momentum, while other times it's seemingly in neutral, the rev's go skywards and we start coasting.
Today, when it did this, i.e. I shifted into 4th and all I got was neutral (or no gear), I stopped the car and took a picture of the gear selector at the gearbox end to see if there's anything amiss. I also took some measurements of the distance that the base of the selector was from the surface of the gearbox.
I then continued my journey, got it into 4th gear properly, stopped the car and did the same. There is NO discernible difference at all to the position of the gearbox selector. The measurements are also exactly the same. So from the outside, the selector is in exactly the same position.
The ONLY difference is that when I'm in actually in 4th I can wiggle the gear stick a little to the right. But when it's doing that weird thing where it feels like it's in 4th but isn't there is no lateral movement in the gear stick to the right. It's as if it's jammed against something.
I thought this was something to do with the gearbox, so I had it looked at and refreshed. But it's still doing it much to my annoyance.
What could be causing this?
Additional info: I have a Rennshift shifter, and a complete Rennshift setup all the way from the gear shifter to the gearbox, and have had for some years. The gear stick is adjusted according to the manual (same way I've done it for years) and it selects all the other gears, every time, with no problem. I also have solid mounts up front on the engine and stiff rubber mounts at the gearbox end.
It seems to do this more often when I'm in race mode or vigorous driving mode. Driving like miss daisy it goes into 4th every time.
I don't know much about gearboxes at all, but to me it feels as if the shift fork is going under the shifter selector thing for 4th and 5th in the gearbox and get's wedged there. Hence not selecting 4th but feeling all the world like it's gone in there as it's moved (at the gear stick end) into that 4th gear position. I'm wondering if there's some kind of shim I've accidentally lost that is supposed to go on the shifter fork thing that goes into the gearbox that stops it travelling to far downwards and hence under the 4th/5th selector thingy.
I'm really starting to loose my marbles with this problem as it's costing precious racing time. Please help
