falcor75
Mar 9 2015, 12:24 AM
I need to order some tires for my project. Will 205/50/15's on a 7" wide Cookiecutter rim work in the rear on a narrowbody car?
The rim alone just clears the outer fender (the inside lip has already been cut/tucked by the PO) but I'm unsure how much the tire will add.
Ideally I'd want 195/55/15 tires but the Federal RS-R's arent available in that size.
If the 205's wont fit I'll have to go for 195/50/15's instead but then the speedo will be a bit more off the scale.
Geezer914
Mar 9 2015, 06:07 AM
I have BFG 205/60/15 on Mahle 5.5 rims and I can just fit my finger between the lip and the tire. The lip on the rear fender has not been altered.
Mark Henry
Mar 9 2015, 07:04 AM
I find that tires that are not the stock height just look odd. OK if you are after something for AX, but for street I'd go with 195/65-15 or 205/60-15.
If you want a lower profile get 16" or 17" rims.
The original 165r-15 translates to 165/83-15, the 185/80-15 was a good fit but they haven made those in ages.
7" rims on a narrow body will likely have big clearance issues.
Mar 9 2015, 07:17 AM
QUOTE(Mark Henry @ Mar 9 2015, 09:04 AM)
5.5"- 6" wheels work. do you want the widest wheel that will fit and compromise on the tires or do you want a good fit, good ride and a combo that looks right.
messix
Mar 9 2015, 08:50 AM
Lots of people have made the 7s work with some pulling on the.wheel lip.
sfrenck
Mar 9 2015, 10:25 AM
I recommend (again) that we get a wheel/tire thread going where everyone can list wheel type / size/ offset, tire size, narrow body/wide with pictures.
Important thing would be to have the information entered in the same format so that it can be searched.
patssle
Mar 9 2015, 11:11 AM
QUOTE(sfrenck @ Mar 9 2015, 08:25 AM)
Agreed. Tire size, any body modification, any rubbing, picture taken at tire height, general car profile picture. That would be great info to have.
Unfortunately the 195/65 or 205/60 tires aren't nearly as gripy as you can get in the /55 size.
Mar 9 2015, 11:54 AM
QUOTE(messix @ Mar 9 2015, 10:50 AM)
Falcor75 has already painted his car so he would run the risk of damaging his paint and/or making the bodywork wavy if he was to try and modify now. It doesn't hurt to check the fit if you can easily exchange or return the tire. A 205x60x15 tire is a whole lot of grip on our cars. A low profile tire will also result in a harsher ride and unless your roads are really smooth, you might not like the results. .. But it your car to do as you please...
Dave_Darling
Mar 9 2015, 04:31 PM
Don't count on it fitting, chances are pretty good that it won't. Most 914s with stock fenders cannot fit 205s on 7" wheels under one rear fender or another. A few can, but those are exceptions. Most of the time, some fender modification is required.
Heck, Rich Johnson had his trailing arms modified to move the bearings in something like 1/4" to 1/2" in order to fit 205s on 7s under his fenders.
Note that you cannot predict exactly what combinations of things will fit on a 914, because not all 914s are identical. Don't forget that there was a good bit of hand-work still done on these cars when they were built, so there are changes from chassis to chassis.
--DD
Hank914
Mar 9 2015, 07:39 PM
"A low profile tire will also result in a harsher ride and unless your roads are really smooth, you might not like the results."
I ran some 205/50s that were on some Fuchs I bought. I did not like the look, but I hated the ride. So harsh it jolted the engine lid open regularly.
brant
Mar 9 2015, 09:40 PM
I think guaranteed fit for that rim on a stock car is 185 tires.
On that cookie you might get 195. And a few report to get 205.
I how ever failed to get 205 on three conversions 5bolts I've had.
You can pull the fenders. It might crack the paint. Use search, "heat guns"
vielspass
Mar 9 2015, 09:44 PM
i recently read someone at pelican recommended 195 60 15, bigger than original 165 but well within ability of fitting wheelwell.
i am looking to get new tires soon so i would be interested in what has beeen useful for regular street driving.
brant
Mar 9 2015, 10:09 PM
The six cookie will likely fit a 205 because it has the extra inch of lip clearance
Dave_Darling
Mar 10 2015, 12:53 AM
QUOTE(brant @ Mar 9 2015, 08:40 PM)
Good luck getting a 185 seated on a 7" wheel. I know someone who had 195s put on a set; his tire busters were not happy about the experience...
--DD
rgalla9146
Mar 10 2015, 12:01 PM
I agree with Dave, 205 / 50 15" on a 7" fit on one side of my car and was too damn close on the other.
falcor75
Mar 11 2015, 09:15 AM
I just ordered a set of 195/55-15's so hopefully they will fit.
