krazykonrad
Mar 9 2015, 08:27 AM
Does anyone have some plans/diagrams of a full car rotisserie?
Thanks in advance,
Konrad
CptTripps
Mar 9 2015, 08:39 AM
There are a TON of ways you can build one. No plans per-say, but if you start by welding up a template based off the front bumper mounts, you can get pretty close.
Just make sure you brace your door jams before you raise it up!
mgp4591
Mar 9 2015, 08:49 AM
Do some searches on the site- I've seen some innovative designs from steel to...wait for it... 2x4s that actually work! Some are really trick, others' merely work but they get the job done. Happy searching!
Mar 9 2015, 11:14 AM
barebrad
Mar 9 2015, 01:39 PM
The Restoration Design website has some plans online as well.
http://www.restoration-design.com/media.htmlThey have a different approach to the rotisserie. It is 2 octagons that hold the car and you just roll it over. I've built one and it works well for me. I like it because when I'm done, I can break it down to real small parts that don't take up shop floor space...
Mar 9 2015, 02:47 PM
AndyB
Mar 9 2015, 04:16 PM
I bought a kit from Tangerine Racing. Took all the guess work out for me.
infraredcalvin
Mar 9 2015, 11:18 PM
I built this one. I had to mod a few items based in availability, but I like the parts list.
http://blueskymotorsports.com/index.php?op...18&Itemid=1Good luck!
cary
Mar 16 2015, 07:57 AM
Here's a couple shots that I took at a shop in Costa Mesa. I think I'll modify my rotisserie so that its not hanging by the bumpers. It would have gave more support in the right places when I had both longs off/out.
Click to view attachmentClick to view attachment
bandjoey
Mar 16 2015, 08:24 AM
Someone here even built one from wood. Pictures anyone?
mr914
Mar 19 2015, 10:29 PM
CptTripps bought/used mine, which I built.
He is right, build your yokes out of 1" tubing and pit a 6x8" 1/4" plate on it and then the fun part. Determine your centerline...
Materials...
Aprox 2" tubing that slips between other tubing.
I went to my local steel shop and told him I needed slip fit square and round tubing.
Also hooked me up with a combination of 2" thin and thick wall square tubing.
Had to get my local machinist to precision bore holes on 2" centers
Bought some "D" rings from harbor freight in 1 and 2" sizes.
Casters I used were overkill, but would roll over almost everything
Added 2 short length cum alongs and I was good to go.
Ask the captn how it worked for him.
mr914
Mar 19 2015, 10:32 PM
Forgot to say buy 8 1/2" t-handle pins to hold the assembly together
Bore 5/8
mr914
Mar 19 2015, 10:35 PM
In use,
Will break down to fit in small wagon or sedan with a ski condom
infraredcalvin
Mar 20 2015, 12:36 AM
QUOTE(bandjoey @ Mar 16 2015, 07:24 AM)
http://www.914world.com/bbs2/index.php?s=&...t&p=1020028
