I'm at the point that I will be reinstalling my gauges here pretty soon.
Is there a way to test these not to mention get everything hooked up the right way?
The 912E came with from left to right:
1 - Fuel gauge
2 - Oil Temp
3 - Tach
4 - Speedo
5 - Clock
I am making several changes, but want to be able to test the gauges before installing.
1. Eliminating the stock fuel gauge and using a VDO mounted in the center gauge cluster with a CHT & Clock. The CHT & Clock are no brainers, and the fuel gauge is a new gauge and known to match the sender. How do I test the sender? Make sure I have the right wiring?
2. Adding a 911 Style Oil Temp & Pressure gauge. I did add and/or swap put the senders to match the gauge, will run a fresh wire for the pressure gauge, and will move the wire from the temp sender to the new gauge, but how do I test the gauges themselves?
3. TACH - How can I tell if my TACH is good? Battery? volt/ohm meter? potentiometer?
4. SPEEDO - Same as above, how can I tell if it is good?
I'm going to assume the idiot light circuits will still work, but I have to say that the gauge cluster and wiring is just out of control.
NOT feeling a warm and fuzzy about this...... I have been as perplexed at the over complexity of the wiring choices of this car as I was impressed and amazed at its mechanical simplicity and brilliance...... Just 5 minutes dealing with the insane routing of the front parking/head/directional is enough to convince that the communists must've infiltrated Stuttgart on the day they drew up the 911 wiring harness.....
