QUOTE(Jeffs9146 @ Mar 10 2015, 03:10 PM)
yeah, something cheap and use alot of it. Simple green can be diluted, Marine Clean is awesome, but not cheap.
You have it totally apart and split, right?
if all you have done is remove the cooling tin, you might just use a bunch of rags and a tooth brush, you don't want stuff getting inside. water proof and seal the intakes, etc.... or just crack it open and blast it with a hose. But only if it is totally apart, like you are looking at the crank and 2 halfs of the small block.
