QUOTE(Porschef @ Mar 10 2015, 03:38 PM)
Elliot, yes I did see your pic before, it's just that the header pipe gets in the way and it's hard to tell just what's going on. But you didn't need the banjo bolts,correct?
Strat, I do realize there are less expensive ones out there, the Mocal unit is the only one shown with those bolts, Aircooled.net also shows the same for the type4...
Sherwood, I do have a remote thermostat, it's an Earls that is essentially the same as the one you're referencing. I was just making an attempt at simplification, eliminating extra fittings/plumbing
You might try something like his AN fitting if you have room. It might be a bit cheaper than banjo fittings.
