VWTortuga336
Mar 12 2015, 08:29 PM
My front hood looks like it was bent somehow by the PO. I took it off and I think I have reshaped it to where I want it. Problem is, I can't easily test fit it because spring loaded hinges are in the way.
What is the best (safest) way to remove the hinges? It looks like the springs attach by hooks into the fender, but I'm not able to stretch them enough to release them. Is this my best option?
Mar 12 2015, 08:46 PM
Leather gloves. Grab the spring. Pull. Remove.
sorry, double post
jcd914
Mar 12 2015, 10:57 PM
I use large vise grips clamped (very tightly) to the spring near the hooked end and pull to unhook the spring.
Jim
GermermanCarGuy
Mar 13 2015, 07:34 AM
Using 2-3 ft rope, loop through hook at fender mount and pull. You can reattach using the same method.
More secure than pliers and more leverage than via screw driver or your hands.
914work
Mar 13 2015, 07:39 AM
MC tool specifically for the purpose of removing installing (exhaust) springs
Looks like a T handle w/ a hook at the end.
TheCabinetmaker
Mar 13 2015, 08:08 AM
I use the rope method but with a coat hanger and a hammer for two handed pulling.
rhodyguy
Mar 13 2015, 08:24 AM
Coat hanger. If the hanger gets trapped on the wrong side, just cut it, and get another one from a closet. Hanger needs to be the continuous loop version.
dlee6204
Mar 13 2015, 09:18 AM
QUOTE(mepstein @ Mar 12 2015, 10:46 PM)
Quick, easy. Never had a problem doing it this way.
