RickS
Mar 14 2015, 03:10 PM
Got a new rear bumper top and need to pull the bumper. I see a nut under each tail light in the trunk, but what is involved in locating the others? Do I need to pull the muffler and how do I remove the heat shroud? Thanks
And searches got nuttin' on dis
Jeffs9146
Mar 14 2015, 03:27 PM
It is under the inside rear of the fender directly below the one in the trunk.
Just remove the 4 bolts and the bumper falls off.
KELTY360
Mar 14 2015, 03:46 PM
Be prepared for some rusty bolts, PB Blaster is your friend.
RickS
Mar 14 2015, 04:02 PM
Also found I needed to remove the lights and and the nut above the lights. The two bolts in the rear were easy to locate after I put a light in the area.
Did not need to pull muffler or heat shield.
