QUOTE(Dave_Darling @ Mar 16 2015, 08:19 PM)
You pull the stalk, you don't hear a click and the low beams stay on?
The stalk isn't plugged in correctly, or you borked the microswitch when you had everything apart.
--DD
it may have happened when he used a snap-blade knife to remove the goo from the lower windshield edge while replacing his dash top thereby cracking his windshield (and blaming it on his pal ((me)) then, in a fit of uncontrolled slashing probably sliced thru the wiring harness below the dash... somehow......
See Page 01-2/9 ELECTRICAL WIRING DIAGRAM (PART II) Type 914, Model 72 - USA DUH
