QUOTE(r_towle @ Mar 16 2015, 04:42 PM)
The piston sticks due to rust inside.
Calipers do not retract, ever.
They are pressed by the power of the hydraulic system, but they retract by simple variations in the rotor tapping them, just a hair.
Also, the pressure needs to be relieved.
There are two causes, but first see if the rear caliper in question is hotter than the other on an average trip.
If it's hot, could be two things.
The rubber brake line gets clogged from the inside, similar to clogged arteries.
Just old brake fluid does this, and 40 years.
So this can prevent a caliper from retracting.
Then there is a harder one which is the piston is not retracting into the caliper.
For that, buy a rebuild kit from Eric at PMB, pull it apart, clean the inside of the cylinder, put it back together....done.
With custom calipers also check you are not rubbing the wheel inside, and you are not rubbing the dust cover.
Rich
Well I may have found the issue but I'm not going to take it for a spin until tomorrow. Both front wheel bearings were loose. Funny this was the first time I actually went to the archive and found that they want that slotted washer to move but still be tight. I have always just felt the right spot. Both were loose to the point of movement when I tugged at the wheel when jacked up. Used my feel as I have always done and it spins with no wiggle. We shall see........ thought the sound was coming from the rear but hell who knows.
Dave
