I posted a WTB ad here because I think my proportioning valve is dead. I'm sending off all 4 calipers to be rebuilt because the pistons are rusty, as the car has been sitting for years. I "tested" the valve by removing the rear calipers and pressing the brake pedal several times. By this point, I had lost a lot of the fluid (through screwing with getting the fronts off, then back on to remove the pistons, etc.) and obviously introduced lots of air into the system. When I pressed the brake pedal, no fluid came out of the rear lines. I can get compressed air through the valve no problem. Is this because I couldn't build enough pressue to get fluid through the valve, or is it actually bad?
I know I should have posted this question before my WTB ad, but I got trigger happy on buying my brake components
