QUOTE(shandyhaggis @ Mar 17 2015, 05:14 AM)
QUOTE(mepstein @ Mar 17 2015, 04:17 AM)
QUOTE(sfrenck @ Mar 17 2015, 07:25 AM)
Refurbish them by putting them out for recycling after you by a set of Fuchs
Ouch
But I wouldn't spend much money on the rehab. Good cleaning. Mask and paint from a rattle can.
I was thinking of polishing machine and paste of some sort. The black pain is almost perfect its more the metal that needs a clean.
I might try a small area with polish and see what happens
Shandy - 1st check if they are the polished or brushed (less common) aluminum finish.
If polished or if you want to take brushed to shiny (more work), then a good aluminum wheel polish + elbow grease (always required in the corners & nooks) & a polisher should bring them up.
If brushed & keeping that finish, then use a brass wire wheel in the same direction as the original brushing, then finish with 000 or 0000 brass wool & aluminum polish to bring up the shine. Use brass not steel wire & wool cuz the aluminum is soft & steel would be too aggressive.
My guess is that once polished or brushed to a new crisp finish, then you'll see that the black needs a repaint with satin (Wurth or similar auto rated rattle can spray paint available over there in UK), so just prep with clean loose paing & rough surface for adhesion, mask & shoot!
BTW - those are the original Rivs cuz they have smooth rim edges without the lips. I agree that they look nice on 914's & an economical way to get a 5-spoke wheel without a costlier 5-lug conversion.
PS - you can also get the silver flat-cone plastic center caps to fit them on TheSamba.com from several of their vendors. The originals had the Reverse-R Riviera Logo on them, like on mine - which are the brushed BTW & why less shiny. However, I will be "going back" to the 2L Fuchs originally on my 73 914-2.0 "914S" just to be factory correct for the CW crowd, but will probably resto the Rivs for a set of "DD tires."
Click to view attachmentFYI - by 75-76 from the factory they had either the base (non-option) "star mag-style" steel wheels painted silver, or the optional Fuchs 2L forged alloy or Mahle 4-lug "Baby Gas-burner" cast alloy mag wheels.
Cheers!
Tom
