QUOTE(JmuRiz @ Mar 18 2015, 06:25 PM)
Jeff, I've seen your setup before, but I'm not sure I found out what parts were used to make it.
As for the intake system it is totaly stock "modified"!
The air box was cut off the intake and replaced with an early Volvo 240 series FI AFR mounting box and all the lines were bent to adjust for the movement of the air box. All the misc. smog and decel valves were removed and either capped or routed with adapted pieces modified to fit.
Here is a photo of the Volvo Box to mount the AFR.
Ohhhh and the Yellow elbow is welded and powder coated to match. The rubber pieces are from 2 2.7L intake boots cut in half to allow extra rubber to clamp on the elbow. If I did it again and knew how to weld aluminum I would have done the elbow out of aluminum!
