QUOTE(airsix @ Jun 5 2003, 08:50 AM)
Based on my own PEFI project experience, I'll venture to guess that the assembly time of the megasquirt would be a drop in the bucket compared to all the time you will dump into getting a good working crank sensor and TPS fabricated and fitted. Oh, and don't forget, you'll be building a wiring harness. All of these things are very doable, but I REALLY REALLY underestimated the time it would take.
Hunt is spot-on with the Dirk Wrights Disease (DWD) comment. Your project will run off on you if you aren't carefull. Last month I dropped the engine to do a clutch TO bearing change and look what happened: hydro clutch conversion, clutch (everything from fork pivot to main seal), shift bushings, pedal box rebuild, full engine scrub-down, repaint tin, new throttlebody, re-plumbed fuel lines, fabricated new crankfire setup (sucessful this time I think) ... Day before yesterday I came-to. I looked down at the intake runners I was painting and said "That's it. No more. I'm putting it back together." Hopefully I can fire it off tonight. Right after I build a bridge circuit for the idle solenoid.... Crap it's happening again. (sigh)
-Ben M.
The crank trigger mounting is the big "unknown" in my set-up.
Ben what was your solution?
As far as the DWD, I don't plan to do much with this 1.8 engine, just stick on the FI and hopefully shove it back in. I will save the DWD for the 2.0 (maybe 2.3L) that I’m slowly gathering together parts for. The SDS comes with a wiring harness, I don't know if I will have to modify it much.
I will have a lot of answers soon, I should have my system sometime next week.
Unfortunately, I have 3 customers’ engines that have to be built before I can start on my install. Hopefully this won't slow me down too much.
