The front comes out after removing the windshield chrome trim.
Easiest way is to to take a safety razor blade and push in
severing the clips that hold the trim. The trim is very thin and bends easy.
Purchase replacement clips before hand-they are cheap.
The windshield is stuck on with butyl. Once you get the trim off you will need to
push the windshield out from the inside - Gently-. They are fragile. You will need
to work around the edges- warming the butyl sometimes helps. Do it in hot sun.
If the windshield breaks they are readily available new for @195$
Don't recall how the rear glass comes out. It also has butyl around the edges and comes out from the inside of the car (pushing from rear forward). Think it has trim but can't remember. Most simply fall out, the butyl is so old....
