QUOTE(Racer Chris @ Mar 21 2015, 04:22 PM)
If you follow the included directions to replace the diaphragm and seals included in the kit - the MPS will operate as it did before the diaphragm failed.
Click to view attachmentIf you replace the stock stop screw with the one included in my tuning kit, and you install a wideband air/fuel meter in your car, its fairly easy to improve the overall tuning of your engine.
Click to view attachmentChris and everyone
Wouldn't a wide band air/fuel meter be overkill for my stock engine (what do they cost, I am a poor European with an expensive hobby). Could someone PM me Tangerines diaphragm installation instructions?
I have read the strip down and tuning instruction for the MPS on Rennlist it seems pretty straightforward. However some equipment is required a vacuum pump an LCR meter,.
The LCR meter recommended on Rennlist costs about $350the the cost of these products plus the diaphragm kit make it cheaper to buy a reconditioned unit From AutoAtlanta, although this would be not as much fun as repairing the unit myself.
Question: If I replace the diaphragm do I need to calibrate using a LCR meter or is there a workaround?
Thanks
