Harpo
Mar 22 2015, 06:09 AM
Good morning 914 world,
I need to remove my fresh air blower assembly prior to going to paint. I have tried a search but no luck. I really only want to be able to remove the grill under the cowl so I can replace with my new one from 914rubber after paint.
Thanks
David
TheCabinetmaker
Mar 22 2015, 06:54 AM
Remove fuel tank then pretty much everything you see behind it.
Harpo
Mar 22 2015, 07:51 AM
The fuel tank is out. Where are there fasteners holding the blower in place?
Thanks
BeatNavy
Mar 22 2015, 08:08 AM
There are three (or is it four?) bolts on the side that bolt UP on the top part of the blower box assembly. They are underneath the cowl. Of course you have to disconnect the control cables (take a picture so you know how they are oriented!), the 4 prong connector in the back, and the actual fresh air tubes.
Harpo
Mar 22 2015, 10:24 AM
Thanks everyone, I found the two screws and pulled out the fresh air blower.
David
