Hi All,
It was a nice day today outside of D.C. and I "tried" to drive my teener to work but it would not start.
Later tonight I came home and tried again (it has been running fine last week). I noticed that I was not hearing the fuel pump come on with the turn of the key. I pulled the relays and replaced all three on the board with ones known to work (they took a trip through the headlights first as a test). Still it would only crank - no fuel pump. I then pulled the fuse and found it melted, but it did not blow cleanly. It sort of collapsed. I replaced the fuse with a 25 amp one and verified that the blower fan was working for heat, but when I crank at the ignition still no fuel pump energizing.
Do I access the fuel pump and put 12 volts on it directly and see if it runs? Could the pump be fried? I hope I have not done any wire damage. This is a bone stock D-jet from a fellow board member who turned over a nice car to me....never had any issues with it. Any and all help appreciated.
thanks,
Reg
