QUOTE(bigkensteele @ Mar 27 2015, 07:07 PM)
Man, I am really learning a lot about the tank sitting on my shelf from your trials and tribulations. I am becoming concerned about mine, even though I probably won't be installing it anytime soon.
If I recall correctly, you also had the oil filter fitting drilled off-center, and it seems there was something else besides the subject of this thread... ???
Yeah that was my tank. But you know - it became a gift in the end. It forced me to go with a remote oil filter mount (after a TON of research to find what would work) which allowed to install an oil temp sensor into the mount (and a gauge into the center console). Then last month I installed an oil cooler and put the fan temp sensor into the filter mount as well. No couplings or sensors obstructing oil flow.
Just measure and see if yours was drilled center - easy to find out!
