QUOTE(SirAndy @ Mar 28 2015, 11:43 PM)
QUOTE(BK911 @ Mar 28 2015, 03:27 PM)
Just on the jack post, not underneath. Thinking of just blasting and por 15 ing. No welding. Whatchu think?
POR15 does not work as advertised ...
Oh contraire.... What you might have thought you said was, "people don't follow the directions when using POR-15." Which is absolutely true.
3 or 4 steps: 1a. if needed wire brush the hell out of it. 1b. use marine clean, several times at your favorite strength mixture. 2. use metal ready 'til it stops bubbling, rinse thoroughly, dry thoroughly then finally you 3. paint. if 2 coats then hit #2 while #1 is tacky. If #1 drys you have to ruff it up. If the part is going to see sunshine, then you must top coat POR. It does not like UV, gets ashy, but still works.
Todays society is MICROWAVE. Everyone wants it NOW. Think CROCK-POT and the world will be a better place. and 90% of painting is the prep. My 2 cents and I don't work for POR.
Click to view attachmentClick to view attachment
