914ltd
Mar 28 2015, 04:46 PM
Door panels are too thin for shops "short" staples. Anyone know a source for original length staples? Thanks, Brad
partwerks
Mar 28 2015, 07:07 PM
Brad,
Do you have a picture of the staples you are referring to?
scotty b
Mar 28 2015, 07:24 PM
vinyl basketweave wraps around the edges of the door panels and they are stapled to the fiber panel, around the edges on the backside
914ltd
Mar 28 2015, 09:12 PM
The tips of the staples went all the way thru the fiberboard and created a lot of little lumps where the barbs went thru. These staples were the shortest the shop had. I measured the total height of an original staple and it is only 4mm.
rangrbob
Mar 28 2015, 10:55 PM
QUOTE(914ltd @ Mar 28 2015, 09:12 PM)
Brad you'll need to find a source for 5/32" 22 gauge staples. Similar to the ones in the link below. The hardest part may be finding a gun that will shoot them. I used one that says the minimum length is 1/4", but it worked fine.
http://www.stapleheadquarters.com/Categori...aspx?Id=Senco_CI can get you the info on the staples and gun I used in a couple days if you want.
Karl
TheCabinetmaker
Mar 29 2015, 07:39 AM
I agree with Karl. 5/32" is only .001 less that 4mm. A cheap Hitachi staple gun should handle those.
BarberDave
Mar 29 2015, 07:54 AM
BRAD : The upholster used the wrong staples, seems to my it's his job to
correct the error. Dave AKA BARBERDAVE
914ltd
Apr 8 2015, 08:11 PM
Thanks all. I am now correctly stapled. 5/32 is the answer. Brad
KELTY360
Apr 8 2015, 11:35 PM
QUOTE(914ltd @ Apr 8 2015, 07:11 PM)
5/32...good to know...all this time I thought the answer was 42.
nomore9one4
Apr 9 2015, 07:35 AM
5/32" and shoot the staple in at a slight angle!
